Module passerelle FXO 8 canaux VS-GW1600 et VS-GW1202
OPV-VS-GWM800O
Ce produit n'est plus en stock Disponible en quantité limité, contactez-nous pous plus d'informations
Date de disponibilité:
OpenVox VoxStack Series Analog Gateway is an industry 1st open source asterisk-based Analog VoIP Gateway solution for SMBs and SOHOs. With friendly GUI and unique modular design, users may easily setup their customized Gateway. Also secondary development can be completed through AMI.
There are three Analog Gateway models , the VS-GW1200-8O, the VS-GW1202-16O and VS-GW1600 Analog series. The VS-GW1200-8O can support 8 channels, the VS-GW1202-16O can support 16 channels at the same time, and VS-GW1600 Analog series can support up to 40 channels synchronously. The Modular Design Analog Gateways are developed for interconnecting a wide selection of codecs including G.711A, G.711U, G.729, G.722, G.723, ILBC, GSM. The Analog Gateways are 100% compatible with Asterisk, Elastix, Trixbox, 3CX FreeSWITCH sip server and VOS VoIP operating platform.
Software & Platform:
| Product Model | Specifications |
| VS-GW1600-8O | Passerelle VoiP 8 ports FXO ports |
| VS-GW1600-16O | Passerelle VoiP 16 ports FXO ports |
| VS-GW1600-24O | Passerelle VoiP 24 ports FXO ports |
| VS-GW1600-32O | Passerelle VoiP 32 ports FXO ports |
| VS-GW1600-40O | Passerelle VoiP 40 ports FXO ports |
