Module B200M
Module B200M 2 ports BRI
Module B200M pour les cartes de la série X204
Peut être configuré pour les modes TE et NT individuellement via des jumpers.
Jusqu'à 4 appels simultanées sur 2 lignes ISDN BRI.
OPV-B200M
179,60 € HT
5 - 9 177,80 €
10 + 176,01 €
  • Spécifications
    BRI ports can be configured for TE or NT mode individually by jumpers. It can provide 4 simultaneous voice calls over 2 ISDN BRI lines, turns your legacy ISDN BRI equipments into powerful Voice over IP devices and provides a soft migration path from ISDN technology to the new Voice over IP world.
    Module pour cartes OpenVox X204P/X204E
      Module   B100M
    BRI Port2
    Dinmensions (mm)5*3.9
    Weights(g)8
    DTMF Detection√
    Bus Master DMA√
    Voltage Detection√
    Hardware Watchdog√
  • Caractéristiques
    • Jusqu'à 4 appels simultanées sur 2 lignes ISDN BRI (par slot PCIe)
    • Mix TE and NT Modes as Required
    • TE/CPE mode: BRI or PRI module can be used as transceiver synchronous clock, and the clock source line does not require link to the card
