Yentek B100 - Carte mère Mini ITX avec processeur 8565U, I726L, 2 ports GbE
HZT-ITX-B100_I726L
Ce produit n'est plus en stock
Date de disponibilité:
Carte mère avec un processeur i7 puissant et pouvant avoir jusqu'à 64Go de mémoire. Ceci en fait une carte mère de choix pour réaliser un appareil de virtualisation local.
Produit Non. | ITX-B100_I726L VER:1.3(8565U) |
Processeur | Onboard 8th Gen Intel®I7-8565U 1.8GHz quad Core 8 thread processor, TDP 15W |
Chipset | SOC |
RAM | 2*DDR4 SODIMM RAM slot, support 2400MHz memory, up to 64GB |
Affichage | Integrated Intel® UHD Graphics, support DirectX 12 OpenGL 4.5, support 4K 1*VGA port, support the highest resolution:1920X1200@60Hz 1*HDMI1.4 port, support the highest resolution:4096x2304@24Hz 1*LVDS port, support dual channel 24bit. EDP port optional, defaulted LVDS |
LAN | 2* RTL8111HS Gigabit Ethernet, support Wake On LAN、PXE function |
Stockage | 1* SATA3.0 HDD port, transmission rate up to 6Gbps1 * MSATA slot, support Intel protocol SSD, transmission rate up to 6Gbps1 * M.2 slot, support M.2 2260/2280 NVME PCIE x4/SATA SSD auto detect |
Audio | Integrated ALC268 dual channel high fidelity audio controller, support MIC、 Amplifier support 2Ω5W speaker |
Slot d'extension | 1* Mini-PCIE slot, support WiFi/4G module |
Interface I/O | 2* USB3.0 port 1* HDMI port 1* DB15 VGA port 1* RJ45 Gigabit LAN port 1* Line-out(green), 1*MIC(red) 1* DC12V power connector, support 12V power input |
Interface I/O intégrée | 1* JVGA1 port, 1*12pin (same with DB15 signal) 1* JHDMI port, 2*10pin, same signal with HDMI port 1* LVDS port, 2*15pin, support dual channel 24bit 1* LVDS backlight power supply port, 1*6pin 1* Screen dimming function port, 1*4pin 6* RS232 COM port, COM1/2 support the 9th pin charged function, COM2 support RS485 function 1* PS/2 KB/MS port (red), 1*6Pin 6* USB2.0 port, 2*5pin 1* Front audio port, 2*5pin 1* Front panel switch button and LED indicator port, 2*5Pin 1* SATA power supply port, 1*4pin 1* Amplifier port, 1*4pin 1* 4pin ATX power connector (support 12V input output) 1* SIM slot 1*4pin CPU smart fan connector, 1*4pin system fan connector ventilateur |
GPIO | Support 4-way input output GPIO function |
BIOS | 128Mb Flash ROM |
Watchdog | Support hardware reset function (L256, 0~255 seconds) |
Alimentation | Adopt DC 12V power supply |
Système d'exploitation |
Température de fonctionnement | -10℃~60℃ |
Température de stockage | -20℃~70℃ |
Humidité | 5%-95% relative humidity, non-condensing |
Taille | 170mm x 170mm |
